I thought they were for balancing the tyre not the alloy wheel? Aren't the alloys already balanced?That many weights on an OEM rim??
Ok, let me re phrase that, stickies are harder to get perfect than clip ons, and go out sooner, due to falling off.
The chap where i have mine done told me that.
The machines at places like Pro-Tyre have an arm into which the weight is placed, this is then extended to the distance required, and the weight stuck to the inside of the rim. You cannot really get more accurate. As for them coming off, I've never had a weight come loose in over 10 years of using stick on weights.
where are the paint spots in relation to the valve?
Meant on the tyre, see my first post.
Paint spots on the tyre have no direct relation to teh valve, but they do indicate the light (not heavy) part of the tyre and it's logical to align the light part of the tyre (paint mark yellow usually) with the heavy part of the wheel - the valve. You can fit the tyre any way you want, but this way usually reduces the amount of balance weights needed.
My we are being picky!
of course a valve isn't heavy itself, but there is only one valve so it will add a very small amount of weight to that part of the wheel.
After all a 5g weight can make a difference.
The only thing I can think of is the fitter didn't align the tyre properly- the correct way it to line up the valve on the rim with the yellow paint mark on the sidewall, it marks the lightest part of the tyre and should be aligned with the heaviest part- the valve. If the heaviest part of the rim (valve) is accidentally lighned up with the heaviest part of the tyre (paint mark opposite valve) the the wheel will likely need a fair amount of balance weights to get right no matter the wheel/tyre used, it compensates for the incorrect positioning of the tyre on the rim. Not many fitters know this.
The valve, minus the weight of the metal that would fill its hole, weigh less than the imperfections in the manufacturing of the wheel.
The valve rarely falls on the heaviest point.
And if the wheel has a dent or 2, that also moves the COM.
I cant see the spots on the tyre, but there is an arrow directly above the valve so maybe Goodyear use that rather than paint to align with the valve.
Again, I am talking about the tyre (see first post again) not the heaviest point of the wheel, you obviously cannot adjust the position of the valve in regards to the heaviest or lightest point of the rim, but you can fit the tyre accordingly if you know or choose to.
