Please don't advertise your intelligence by using insults.
I will continue to fit tyres to road and track cars the way I usually do.
If you do find some time read: http://www.carbibles.com/tyre_bible.html
Quote:
"The dots on the sidewall typically denote unformity and weight. It's impossible to manufacture a tyre which is perfectly balanced and perfectly manufactured in the belts. As a result, all tyres have a point on the tread which is lighter than the rest of the tyre - a thin spot if you like. It's fractional - you'd never notice it unless you used tyre manufacturing garage equipment to find it, but its there. When the tyre is manufactured, this point is found and a coloured dot is put on the sidewall of the tyre corresponding to the light spot. Typically this is a yellow dot (although some manufacturers use different colours just to confuse us) and is known as the weight mark. Typically the yellow dot should end up aligned to the valve stem on your wheel and tyre combo. This is because you can help minimize the amount of weight needed to balance the tyre and wheel combo by mounting the tyre so that its light point is matched up with the wheel's heavy balance point. Every wheel has a valve stem which cannot be moved so that is considered to be the heavy balance point for the wheel. (Trivia side note : wheels also have light and heavy spots. Typically the heaviest spot on the wheel is found during manufacture and the valve stem is then located diametrically opposite that point to help balance the wheel out)."
) had to put on a lot more weights on the fronts when I had x4 Vreds fitted by him. The rears were fine but the fronts needed more weights and the machine could not zero in as quick as the rears did.
