Wheel nut torque value
10 Aug 2006
Northampton
Wondered if anyone has any data available for what the wheel nut torque value of a 2012 Ford Ka would be?
There‘s no mention in the handbook and varied values when searching the web.
Thanks.
Never in the whole of my life have I torqued wheel nuts to a specific setting, the only time I would consider this is if I was going to track my car and put the wheels under more pressure than normal, you must be joking on a KA
Really? My BMW handbook clearly states the value of 140nm.
I have never had a wheel come loose or fall off in 25 years, and neither has my brother in 30 years, nor my dad in 65 years
Never in my life have a read a bigger load of nonsense but here we are. The OP has asked for the torque setting, not if its worth doing.
OP - this is a good reference: https://blobs.continental-tires.com...0e98145e9a3/download-torque-settings-data.pdf
As tight as you can get them with the tool kit provided with the car. That way you stand a chance of being able to undo with the same tool kit when required.
And buy a spider/X wheelbrace for when you’ve had new tyres fitted so you can slack the bolts/nuts off and then torque them correctly.
