says what matt?
that just using a breaker bar etc is not as good as using a torque wrench. so many people do not trust garages because of their total lack of competancy and you chose not to use a torque wrench because "all garages do it"
says what matt?
The Earth Pin for the sender unit was arcing in the connector, causing the car to cut out. Electrical cleaner and some rough paper sorted that. Arches are good, only a few bubbles on the inside lip which isn't bad for a 12 year old car.
Undersealed the rear while I was under there.
handy to know. yeah like i said, rarely see another mk4 with arches looking that healthy. i normally have a quick gander if i walk past one![]()
How much would a garage/kwik-fit charge to swap front and back wheels around?
I'd do it myself but don't have a torque wrench or a proper jack/stands (yet).![]()
I've never seen a garage torque up wheel nuts.
[TW]Fox;16168830 said:Always torque mine. See no reason not to, its hardly extra faff isn't it?
But then people will always bodge,
Poor ****er who started this thread only wanted to hear its a tenner or whatever![]()
I tend to torque my wheel nuts when convenient too, glad I'm not the only one. I'd wager most people put too much torque through bolts holding alloy wheels on, which can damage them and make removal a pig. I find that garages do them up far too tight and even use air tools which is seriously daft. When I have to put my entire bodyweight onto, and jump up and down on, a breaker bar to remove a wheel nut, something's wrong. 90-100nm is plenty.
Matt82, glad I'm not the only one who derives a very small amount of enjoyment from using a torque wrench either![]()
