DaveMac said:It's only recently that 120mm fans have been adapted as the 'norm' I would think it will be a while before they change.
Side 1 x 25cm fan
Speed: 550~1000 RPM
Air Flow: 90.97~162.82 CFM (MAX)
Noise: 19.54~35.28 dB(A)
Dureth said:Erm more importantly though how the hell are you getting a system that requires much more than 2x120mm fans to cool? As long as you fit a GPU cooler that exhausts out the rear rather than into the case its not hard to keep a case cool. Add on a CPU cooler that blows towards the rear such as the Akasa 120mm one and you have very little apart from the hard disks to worry about.
Getting good airflow and cooling from 2x120mm fans is not hard.
cavemanoc said:Wow - I most definitely want one!!!
Look at the size of that 250mm fan!
ErNciLator said:Do you reckon that would take off and fly!!!?!?!?
It's a frekin UFO!
