Agghhh!!!! After all my previous twitterings on 24"/22" advantages I think I'm going down the 20" route!! The 24" is just to expensive and I've been persuaded by the "same resolution for only a 2" gain (with MAYBE a perceptible sharpness issue) argument to finally go for a 20" model.
I THINK from my research the two most recommended at the moment are the Dell 2007WFP and the Viewsonic VX2025wm - with maybe a Samsung and NEC in there to spice things up occasionally.
So - the age old question, been asked 1000 times I'm sure, but in the simplest possible terms, what would be YOUR preference from the above (or another I've forgotten if you think it's superior) and WHY do you prefer this one?
Budget is about £300 max.
Cheers.
Cheers.
