Which AIO Cooler for Corsair 400C and Ryzen
If i wasn't thinking about RGB i would go with the Corsair H100i V2 at £95.
In fact you add to the H100i the NZXT Aer RGB120 2x120 mm RGB LED Fans with HUE Controller for £65 for a total of £160
I think that would look better than NZXT X62 which also costs £160.
Of course the X62 is a 280mm Rad. The Corsair a 240. the Kraken X52 (240mm Rad) typically costs £140
I ended up fitting the H100 with two HD120 on the rad, a single HD120 on the rear case vent and then two HD140 fans on the front.
Sadly I discovered that the RGB controller supplied with the H100 SP120 fans doesnt work with HD series fans so ended up swapping them all out for HD units.
