Which card do I upgrade to?
12 Dec 2005
Spec is in sig, currently using a 7850 2GB.
I only recently got the 7850 however I do want to upgrade as best as I can...
If I have a budget of up to £250, what should I go for?
Also, my PSU is a OCZ 550W. Would I need to get a better PSU if I go for a more recent card?
Cheers
280X should be a nice boost if your gaming at 1080p, tbh though if it was me, i'd save the extra or sell the 7850 in the hope that some mining fan would snap it up for a decent price and get yourself a 290.
if you go for a 290 get one with custom fans on, the reference ones are loud and hot!!! custom coolers start at £380
looks like you can get a 280x instead
What's the most amount of money you're comfortable spending, and also, have you tried overclocking your 7850? They usually clock very well.
Cheers
PSU should be fine for most single GPU's
I would go for a 770 on that budgets, mining has push the prices up on AMD equivalent (280X), but they do have that extra gig of ram which some games will use even at 1080P but 2 gig is fine for the best part today, but i would recommend saving up another £100 and get a 780, or 290 as this will be safer in the long run, 290 run hot and loud tho, 780 cool and quiet but both preform around the same
