- 18 May 2010
- London
but you do if you have a very low end or no GPU and want to watch 8k videos
Obviously, but a low end GPU will sort that out no issue. There's always edge cases.
Sure. But you don't need much over a half decent chip for web browsing. An 8700k is a monster chip for web browsing.
Either this or simply each thumbnail takes its own thread, the load is divided among all the threads. It doesn't make any sense to use ONE core for the whole load. It won't load soon![]()
yes...many times i notice it using around 14GB to 15GB when I have a lot of browser tabs openScreenshot suggests it's using about 10GB of RAM as well.
HahahahaYou need a thread ripper for browsing the internet on Chrome, if you're using over 100 tabs you need a datacentre.
I cant believe we've reached a point where it is suggested that a 8700k isn't enough for web browsing.![]()
It’s like the poster has become Castiel/Glaucus combined and just goes against the grain for everything just for the sake of arguing, surprised he hasn’t been warned yet.I cant believe we've reached a point where it is suggested that a 8700k isn't enough for web browsing.![]()
Chrome is faster than Firefox in about everything - initial start-up, loading of pages. I stopped using Firefox a decade ago.
I rather stick with intel as I have always suffered from bad experiences with AMD/ATI stuff
This thread is utterly bonkers!
It is not. It is a mid-range chip with limited resources when there are multiple tabs open and each one of them takes a separate and its own thread for execution. I wouldn't praise that poor chip![]()
Which is great, except in the last 10 years things - shockingly - changed. Firefox was rewritten and released as Firefox Quantum, for example. It's faster and lighter than Chrome now in most respects. As for recommending a £800 upgrade because an 8700K isn't fast enough to browse the web... to quote Magnolia - "Just LOL". You can't post a screenshot of your lowest-end-possible 15 watt AMD laptop CPU as justification that an 8700K can't load YouTube. Jesus, man, do you literally just post stream-of-consciousness? I've just upgraded from an 8700K to a ThreadRipper 3960X and there's no real discernable difference in web browsing, so there's your 3900X upgrade suggestion out the window.
I need to upgrade my CPU as just browsing the internet seems to use all it power
Which CPU would you recommend to upgrade from a i7-8700k from ?
The OP complained that his 6-core/12-thread CPU is overloaded by MS Edge.
I can confirm that browsing can be CPU-heavy, which is confirmed by at least several other sources if you check google search.
You are wrong! He can confirm that browsing can be CPU-heavy, which is confirmed by at least several other sources if you check google search!My 8700 works just fine for browsing TYVM. That includes Youtube.
