Hi there
ive been looking a direct x 11 card for a long time now and have been looking at the radeon 5970 series,
i was just wondering what your takes where on these cards compared with the nvidia "equivalent" series compared to prossesing power etc
The 2 5970's i have been looking at are:
XFX ATI Radeon HD 5970 Black Edition 2048MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showproduct.php?prodid=GX-154-XF&groupid=701&catid=56&subcat=1577
HIS ATI Radeon HD 5970 2048MB GDDR5 PCI-Express Graphics Card + Call of Duty Modern Warfare 2
http://www.overclockers.co.uk/showproduct.php?prodid=GX-000-HS&groupid=701&catid=56&subcat=1577
i have limited knowledge when it comes to overclocking and changing the voltages so i dont think i will bother ... is the XFX ATI Radeon HD 5970 Black Edition specifically built for overclocking etc and if so would u recommend it or just stick to the cheaper ones if i dont intend to overclock it.....
I have also heard that the cards get extremely hot so was also lookin at the http://www.overclockers.co.uk/showproduct.php?prodid=WC-060-EK&groupid=962&catid=1520&subcat=1789 and was wondering how easy they are to install and if any water piping or anything is needed to run to them or if they are just a standalone unit
Sorry for the long essays
but just 1 last question ... when the card starts to become outdate ... no this will take a while
but what affects does crossfiring them have i believe this would be linking 2 of the same cards togeather ... or am i mistaken ... Is this easy to do or does it require configuring?
Many thanks for taking the time to read through this and ur responses are very much appriciated
Ben
but what affects does crossfiring them have i believe this would be linking 2 of the same cards togeather ... or am i mistaken ... Is this easy to do or does it require configuring?Many thanks for taking the time to read through this and ur responses are very much appriciated
Ben
