Which fan controller and why?
Any of the lamptron controllers, high watt per channel means it won't burst into flames when you put 3 or more fans on a single channel.
The 7/10w controllers are aimed at single/dual fan per channel. In contrast I think the lowest lamptron is around 30w/channel.
Lamptron ftw. I have Bitfenix Recon, I like it a lot because it look's cool and I can change my fan speeds without moving. Also, it has no knobs which was good in my old case that had a door.
