- 18 May 2010
While I have not tested or used new Arctic P series, the information on internet indicates the P series are a little better than F series. If I was buying Arctic fans it would be P series.
'Air flow' fans versus 'pressure' fans is mostly advertising hype. For air to flow there has to be a pressure differential. Air flows from higher pressure area into lower pressure area, so if there is not pressure differential there is no airflow.
In our uses of fans we always have resistance .. grill, filter, fins, cables, HDD cage, etc. all create resistance to airflow.
Hi doyll, I'm about to pull the trigger on two Arctic 140 P series intakes and one 120 exhaust for a Meshify C, I suppose I'm just making sure this is a good decision as these fans seem too good to be true for the price, over 2.0mm H2o seems high compared to the usually recommended Phanteks fans but the Phanteks arent in stock either
Anything else I should consider or should I just got it?
Cheers
