- 18 May 2010
- London
One upgrade that will benefit you at present would be the addition of 4gb of ram as long as you have a 64bit OS of course.
Upgrading his CPU and MOBO on a low budget then still having to use a 460 isn't going to be that great. Any GPU demanding games will be held back massively.
I guess it depends how long OP would wait before then buying a new GPU as well.
I used a similar cpu (Q8200) @3Ghz with a HD7770 (slightly slower than a 260X) and it was a good balance. A much faster gpu would bottleneck I'm afraid.
That's probably out of the question due to budget constraints. Upgrading the PSU will mean no budget for the GPU.
I've got a Xigmatek NRP-MC651 in another system but is about a year older than the Corsair.
Without changing any other component from the OP, just wanting to see what other GPUs can make a good improvement to my system.
Thanks for the info guys. Those GPUs seem like a great upgrade to my GTX460, are those GPUs okay with my PSU though?
@mzal - I'm going to look into the 771 mod, sounds like a great way to get more out of old tech.
Hopefully not to derail, but is the benefit of these xeons over the q6600 simply down to higher overclocking capabilities or are there other real world benefits?
If you need info on the 771 mod its all here http://www.delidded.com/lga-771-to-775-adapter/
A nicely overclocked xeon will not hold back a newer gpu as much and they are very cheap.
Higher base clock and better overclocking performance. All info here
Thank you all for the information and suggestion. I am on Windows 7 64 bit OS which I reinstalled recently (transferred from using HDD to SSD).
I will see what sort of money the suggested cards cost but might hold off any more purchases for the time being and do a one time over haul which I guess would make more sense, but will be in +6 months.
The OP asked about a graphics card upgrade not proc?? Why try and confuse him with complex modding instructions regarding something he never even mentioned? If his cpu is quad and running 3.3 Ghz then he wouldn't get any bottleneck with the 750 ti.
In fact its a perfect match, and the one i recommended was £80 in B grade.
Bargain... but oh no lets derail the subject to cpu's?.............
A one time overhaul will cost your hundreds of pounds?! The £80 b grade msi 750 ti ( that i earlier linked ) would be the best bang for buck upgrade you could get, and you can upgrade now, not in six months.
Don't let people tell you your proc' isn't good enough. I could almost guarantee you, you'd see a good performance increase, for your 80 quid!
Your choice though dude.....
