Which Graphics Card with 550W PSU
18 Oct 2012
Hi guys, i recently bought the Radeon HD 7850 OC Windforce. Whilst gaming the card kept crashing my system at random times and freezing my system making it unusable.
I contacted support and am returning it as i was told the PSU wasn't powerful enough for the HD 7850.
My PSU is the OCZ ZT Series 550W, i was wondering if anyone could suggest a similar GPU that will work with this power supply or is it worth replacing all together?
Will just add that i'm I am only a casual gamer and looking for a card around £150ish.
Many thanks
To be honest i don't think support we're really that interested, as soon as i said i had a 550W PSU that was it without really diagnosing the problem.
Perhaps i just have a bad card or its not compatible with my setup. Everything is relatively new tho and i just want to get up and running rather than sending the card back and having to wait for testing etc...
550w is easily enough for that card I would have thought. Does it say on the box what the minimum spec PSu required is?
Well i'm glad it isn't the PSU then. I think I am just going to send it back for a refund anyways as there is a problem somewhere, hopefully it is just a defect with that card as the rest of the system is running fine.
Once I get refunded has anyone got any suggestion for a similar spec card? I have been put off the radeon HD series after this.
I would guess you have a problem somewhere else. Perhaps the card itself was fine, its hard to say without trying on someone elses computer or trying a few other things. If you are in the DSR period though you are best off returning it :)
If you're not interested in AMD, then probably something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-177-MS&groupid=701&catid=1914&subcat=1854
The 560Ti performs quite close to a 570, which eats a 7850 for breakfast.
Yes exactly, the motherboard, processor, PSU, case and memory were all new and only installed 2 weeks ago and everything seemed okay. The graphics card was the last thing to arrive and added on tuesday when the problems started.
I have tried 3 different hard drives with new windows installions but still with no luck.
Its just so frustrating after saving up and waiting for so long and then things not working correctly :/
It's definitely not your PSU, don't listen to such ********. I'm running an oc'd 7850 with an oc'd Phenom II 955 BE, 1TB HDD and 4 case fans on a 500W OCZ PSU with no problems whatsoever. I'd say that either the card is faulty or AMD drivers are playing up (maybe your 2d/3d clocks are changing during gameplay or something).
Yeah its kinda stange, i can play on skyrim for an hour sometimes with no problem but then sometimes it will only last 5 minutes. I didn't manage to get that far to explain the actually problem with support.
I've read about a few problems with this card relating to drivers etc but after 2 days of trying different things i'm ready to give up.
I am just happy that its not the PSU which is at fault.
+1, probably the best your going to get for the money.
This bit on the other hand:
8454. 580. 3930K @ 4.6 --------- Rossi
8370. 580. 2600K @ 5.2 --------- Geeman1979
8299. 670. 2500K @ 0.0 --------- Kronos
8279. 7850. 2600K @ 4.5 -------- Wazza300
8043. 660TI. 960T @ 4.1 -------- Imginy
7944. 7850. 3930K @ 4.5 -------- Boomstick777
7924. 7870. IIX6 @ 4.2 ---------- Humbug
7899. 470. 3770K @ 5.5 --------- 8 Pack
7649. 670. 955BE @ 3.8 --------- Madtoady
7571. 7870. I7 860 @ 3.7 --------- AlmostStew1990
7514. 460. 3770K @ 6.0 --------- 8 Pack
7508. 7870. 2500K @ 4.5 -------- Spenty
7244. 7850. 3570K @ 4.8 -------- Gibbo GTI
6470. 7850. 3570K @ 3.5 -------- Arekgreenman888
6415. 560TI (448). 2500K @ 4.4 - Leoncao
6357. 560TI (448). 3570K @ 4.4 - Yjani
6137. 7870. II 965 @ 3.4 -------- Ryan4227
6116. 570. I7 920 @ 3.6 --------- Subaru Swift
6083. 470. 3570K @ 4.2 --------- Pulse
6054. 6970. FX8120 @ 4.9 ------- Angelbambi
6041. 570. 3570K @ 3.4 --------- SkeeterUK
5613. 560TI. 2500K @ 4.5 ------- WhyScotty
5458. 680. E8500 @ 0.0 --------- The Mad one
5227. 7850. I3 @ 3.0 ------------ Wazza300
5207. 560TI. 2500K @ 4.6 ------- Neil79
Take into account 3DMark on the whole runs better on Nvidia
