Which HDD to go for?
7 Mar 2005
Glasgow, Scotland
I currently have a WD Blue 3D 500GB SATA SSD (WDS500G2B0A) as my only drive in my PC. I intended to pull the HDDs from my old PC and use them for storage but they're over 15 years old and one has started to fail, so I assume the other two won't be far behind since I got them at the same time.
1TB should be ample storage space as important files are backed up to the cloud and an external HDD. If I ever run out of space, it might give me the kick I need to repair an old PC I turned into a SnapRAID NAS ages ago (cloud storage was an easier solution when it started playing up but it's an expense that one day I'd like to stop).
I'm looking at the below drives but with the changes in HDD tech since I last bought one, I'm rather confused by the whole SMR thing, which drives use it, or is it something to avoid as opinions seem to be mixed. Any suggestions?
My basket at Overclockers UK:
Total: £82.60 (includes shipping: £8.70)
The Seagate Drive will probably Die well before The Wd Drive. You just have to take a chance these days with Hard Drives.
SMR Drives dont like raid so avoid
if you have could and external backup then I'd reuse an existing HDD for storage and use a 240gb or 480gb SSD for system, it make a really nice difference having an SSD as a system drive.
thanks for the advice folks. CrystalDiskInfo says all my old drives are in poor health and the WD one isn't expensive so I'll just go for that and save any hassle down the line.
Out of those two WD, of all the drives i've had over the years(SG included) the WD drives are the ones that have lasted.
