Which nvme m2 drive - Samsung, Corsair or WD
20 Oct 2010
Hello,
I started buying components to build a pc hopefully with a Zen 3 processor and planing on getting a good 1TB nvme drive for it. I am still on a very old p775 socket Q9550 processor (yes it still runs!) and realised how i need to upgrade since it throttles my gpus. It was fine with a geforce 680 but once i put a Vega 56 the minimum fps was going up and down!
I am a bit confused at the moment of which is the best from the SSD side of things.
Corsair MP510 960GB
Samsung 970 Evo Plus 1TB
or
WD Black SN750 1TB
Hopefully price won't be an issue but obviously if gains are negligible and i can save a good chunk of money to put towards another component i would do that.
What are your thoughts on the current NVME field. Found a few of those on offer we are talking about 50 pounds difference between the Corsair and the Samsung not sure if its worth to skimp or not. Or should I wait till Zen 3 pops up and then see what technology comes up with or prices drop?
For my build so far i already got a brand new PC case (Coolermaster C700p), a corsair 1000w hx, my old 2tb WD black, 2xSapphire Nitro Vega 56 so getting there :P. I plan to get another SSD for storage in the future but probably will have to be sata due to the pci express lanes not being so many.
Samsung Evo plus is the quickest, the WD black is nearly as fast but I would go with the Samsung.
There are a couple of vs videos on YouTube you can watch
Indeed I can find both Samsung and WD roughly same price so I would pick the Samsung. What of the MP510 though you can find the 960GB version of it quite cheaper and its endurance numbers are ridiculous.
Honestly they all perform similarly. The 970 EVO Plus has the edge in some benchmarks with the SN750 not far behind.
The MP510 however is where the smart money is, at £50 cheaper would easily be my pick. It might not benchmark quite as high as a 970 EVO, but it is still a high end NVMe and reviewers have been impressed with it.
I've had both a 1TB MP510 and 970 EVO Plus and outside of benchmarks I couldn't tell the difference between them in typical workloads like booting, game/application loading and virtual machines. Only downside of the MP510 IMO is the poor Corsair toolbox software and the stick is double sided, though it isn't really a problem.
Anandtech has done a 970 EVO Plus review which includes a MP510 in the graphs: https://www.anandtech.com/show/13761/the-samsung-970-evo-plus-ssd-review
I've just bought an MP510 960GB for 150 myself. I just don't think any other 1TBish NVME drive offers anything above it to justify the 30-40% increase in price.
The performance where it matters is roughly the same.
Interested in this too as I'm also doing the same as the OP. I gather I would be better off with an nvme drive compared to a regular SSD?
Depends on what you're doing. For gaming, nvme isn't of much benefit. Real world gains are minimal.
But if you're doing something like video editing or same drive copying (ie stuff that hammers the storage subsystem), then nvme is very useful
Are there any drawbacks such as reduced life etc between the two?
Definitely NVME vs Sata, the NVME wins. I was looking at the evo 860 as well and then saw the price difference and i think its worth to go for an NVME especially in my case that I build a new PC. Saw somewhere the 1.9TB C Corsair for 290ish and was thinking about that as well. If that was 220 i would snap it in an instant. Getting there...
That is what I would be looking at also. Not quite ready to order yet but will do shortly I think.
I think I would be looking at just 1TB for the NVME and have mechanical drive for other less important things.
why wouldn't you just get the 660p M2 then? 2TB, speed is 4 times the SATA SSD's (550~MB/s) although not at TLC M2 speeds (1800MB/s vs 3200+) and can be had for £230.
This could be ideal for myself actually and reasonably priced. Thanks!!
Gives me about 15 times the space compared to my current SSD with a performance increase.
I was checking on that not sure where I read that if it reaches the buffer then its as slow as an HDD otherwise i would have bought one on that price. I take it on day to day use you are not hitting the limit of the buffer, but since i am building one PC every 10 years :P I dont mind spending a bit more and getting something better. My usage will be gaming, movies, web development and programming and maybe some rendering in the future.
