So do I have this right:
1 x HDMI cable from the PS3 to the amp.
1 x optical lead from the SKY+ HD to the amp.
1 x HDMI cable from the Wii to the amp.
1 x HDMI cable from the amp to the tv.
Is this correct?
Where's the best place to get good quality otical and HDMI 1.4 cables - does anyone know? I can't imagine that they will come with the product.
I've got my PS3 via HDMI to the TV and Optical to the amp.
Actually not at the moment because i've moved the PS3 to the PC desk for GT5!
Ohh and i'm very impressed with the Onkyo system for the price![]()
You'll need HDMI to the TV from the Sky and the Wii doesn't support HDMI. The best connection is by a Wii Component cable which will give you 480p. The Wii also only does Dolby pro-logic I think so very little point in plugging it into the amp TBH. My Wii is direct to the TV via said component cables. About £10 for an unofficial set. As for HDMi cables pretty much any cable will do. There's no real advantage in paying through the nose for a better cable, it's all digital, either it gets there or it doesn't. That said, good quality cable can help for runs of 10m+. These would suffice quite happily.
1.4 cables support 3D I believe and that's about it.
You say HDMI and Scart from the Sky box? is it a Sky+HD box? If so then you won't need Scart, just HDMI. You just called it Sky+ earlier in the thread.
I'm starting to doubt that the Onkyo system will ever come back into stock for the price I've seen it for £230 delivered.
Any comparable systems/prices folks? Recommendations much appreciated.
I believe it will, there has just been a delay in the shipment - this is what another supplier who was out of stock said. Thing is though I think you'll be waiting for another 2 weeks at least before it comes back in stock.
The best price you can do apart from that is ~£280 from the jungle river website.
I have the Sony DWG800, got it about 2 years ago so there is probably a newer model on the market, costs about £300 and is similar to the Onkyo setup. It has a seperate receiver so you can updgrade the speakers at a later date if need be, google it and see if it takes your fancy![]()
I'm not fussed about waiting as long as it comes back in stock lol.
Does that £280 include an iPod doc or is it the exact same set-up?
Aren't Pixmania notorious for not getting stock in? They didn't give me a straight answer when I posed the question with regard to their expected restock of this Onkyo system.
I was going to suggest the Onkyo HT-S5305B from the same website but see that the price is now £329 (I paid £279 last night).
