So that is why i have changed fan round in psu to bring cool air into rear of case and out the front.
Ok thanks ive changed all my fan configuration now.
I now have 2 front intake and 1 side intake, Top exaust and rear exaust through H50.
Unfortunatly i cannot have my PSu facing up at the moment due to the 8pin mobo connector not being long enough so will have to get an extension cable for it(this is due to having 2 graphics cards in crossfireX and wont stretch over or under them. So psu will have to stay with fan at bottom for the time being.
Havent noticed much of a difference in temps only HDD's are a bit lower now. CPU and GPU's are still same temp.
Mayfair
Did your case come with 2 tri-cool fans the 120mm and 140mm?
ok see i only had the 1 top 140mm i guess the guys at OcUK took out the other 120mm and left me with the corsair H50 fan instead. I would have liked that 120mm antec tri-cool fan cant seem to get hold of any black ones now only colored led ones, all these fans are out of stock on website.
So your PSU is currently upside down and effectively sucking air from the bottom of your case? Meaning its pretty much sucking in no air :S
I'd sort that out quick...
Hi blitzyuk,I cant turn psu round other way due to 8pin cable being too short and not having an extension cable ive had to leave it with fan facing bottom
. . . There is no problem at all having the PSU with the fan pointing downwards, as you said it is raised from the case floor enough to draw in cool filtered air from the front intakes . . . been running a Corsair PSU for a year and a half like this with no problems at all . . . the PSU's fan barely turns as it is sitting in the coolest part of the chassis and the little bit of air being expelled out the rear of the PSU is cool! . . .
Not really, just wanted to show the two Blue LED fans drawing in cool air and that seemed like a good place to lay the insert . . .Is that small pic to hide the cables lol
Its a pity you had to buy an adapter and now are thinking of buying some mesh when you didn't need either if you had just stuck the PSU with the fan pointing downwards . . . interesting "advice" you received!Well i have re routed the extension cable now so wont be changing it back i could always buy some mesh to put over it just incase of any debris falling in
The Antec 300 is pretty flawless, I'd give it 98% . . . bought ten of them when they were selling for £33 and used them for builds, The only thing I had problems with was clients pressing the power button when they were wanting to eject a CD!How you finding the Antec 300 thats how i had my 8pin mobo connector before straight up mobo. now got it upside of expansion slot covers and under rear fan good thing about having those little holes at back can just get cable ties through.
. . . and also the front fan filter has to be re-attached just so otherwise you get a tiny bit of vibration . . . apart from those two small niggles its a great thermally advantaged chassis!
