DON'T GET THAT PROBLEM ON A MAC
Yes you do.
thats a myth, 2 colleagues with macs, 1 is saying its slowed down a lot and wants to reinstall it but isnt sure how, and the other is saying its slowed down so much its nearly unusable, both no more than a few years old.
I don't I have a Macbook Air![]()
Know what else you don't get on a mac?
Everything.
Haha nothing is perfect bud. Bound to have errors in over 1 million lines of code.
The things I do to keep the pc super fast:
+ Installed an SSD
+ Download CCleaner, run it at start-up.
+ Check when installing software to avoid additional "Bloatware".
+ After installing a piece of software to use on the quick, uninstall it after use.
+ Check for obsolete registry entries. Fix or remove them.
+ keep the hard-drives clean with good management systems.
You should be fine if you do some of these.
Mind going into detail explaining how you go about doing those?
Id like to check im doing roughly what I should be!
