Why does DU Meter show constant dl and uploading?
18 Oct 2002
Newcastle, England
Just wondering if its normal for DU meter to show my connection contsantly downoading and uploading? if I hover my mouse over the icon in the tray it will say.. DL: 4.8 kb/s UL: 5.6 kb/s
Im not browsing or anything?
this will add up towards my monthly usage on Nildram and Im a bit worried about it.
Ive killed most of the suspicious services but its still showing a constant dl ad uploading going on.. is this normal??
A few of the windows services do sometimes access the network, but I've got several internet apps running and I see no activity unless I actually browse\send a message etc.
Cant work it out, check this....
I didnt have any internet site open at all too. :confused:
"wscntfy.exe" is the Windows Security Center, introduced in Service Pack 2. It displays a tray icon indicating the status of updates, virus protection, and firewall.
ali1589.exe is for my raid manager.
I disabled the security centre, just gets in the way. I'm also tired of SP2 blocking harmless files on IM transfers...
How are you connected to the internet?
I use:
Ad-Aware
Spybot Search&Destroy
CWshredder
Spywareblaster
Sounds OTT I know, but it means my system is clean pretty much all the time. Just get the odd tracking cookie once in a while, and if I tweaked browser settings, that wouldnt be a problem either.
Im using a wired connection to the router at the mo, but there is a wireless connection to my laptop, its turned off though at the mo.
This is really starting to alarm me now, take a look at the following screenshot...
Theres no way this can be right? its contantly going up and up too. I really need to stop whatever it is from downloading and uploading here.
I did a scan with spybot and it found trackers etc, I removed them but still my connection shows a constant dl/upload going on. :confused:
the way i see it is you have a couple of options...
1/ turn on all loggin in your router... see what your pc is communicating with, then research what ip addresses your pc is connecting to.
2/ download and install ethereal onto your pc and see exactly what is going across the wire.
see what either of those bring back.
edit: ive also got a dg834g and i thought the logging capabilities were better than this... i think ethereal is the way forward...
Thanks for your help, I'll try that. I have also changed the wep key incase somone had hacked it and was connecting to my wireless signal. Im really puzzled.
wep keys dont take long to break these days...
look on your router to see if there are any additional stations connected to it
