Why does DU Meter show constant dl and uploading?
I have no idea what Im doing here but I looked in attached devices in my router and it says.. device name DESKTOP and an IP address thats not mine?
When I check my ip address its different?
reboot your router, and see if the device re-attaches when it comes back up...
how is your wireless network configured?
i think its about time you changed the ip range of your lan interface, potentially even using a custom subnet mask to limit the number of available ip addresses...
disable dhcp and use static addresses...
then make sure broadcast ssid is disabled...
change your ssid...
change your wep key and make sure it is the highest strength your router will support - probably 128 bit...
look at implementing wpa-psk...
enable mac filtering...
and then see if the person re-attaches! ;)
change your ssid...
Thanks thats really helpfull advice, I will do what you say and report back soon. :)
DUMeter will only show what's going in and out that machine.
The (lack of) security in WEP is an issue (use WPA if your kit will do it), but it's not particularly relevant to what DUMeter's reporting. Try disconnecting the internet connection and see if it continues, or try TCPView.
atomiser said:
is your laptops hostname 'desktop' ? and does it have the ip/mac address of the station attached to your router ?
No my laptop should be called just that laptop. And the laptops ip address is the same as the desktops.
I just changed my wep key to 128 bit and now it shows to things in the attached devices.. DESKTOP and LAPTOP.. both with simular ip addreses apart from they end in 02 and 03
Christ Im confused here?
Those ip addresess listed in there are only 8 numbers and my ip address is 10 numbers?
i just ran whats my ip through my laptop and desktop and it was the same.
Can anyone with a Netgear DG834G router have a look in attached devices and then check there ip and see if its the same please?
Im assuming that you are using NAT, and that you internal IP's are 192.168.0.x or similar. If you run whatismyip with NAT enabled then yes you will see the same IP, as you only have a single public facing IP address.
Also, DUMeter will only record incoming and outgoing connections from YOUR pc, nothing to do with the Laptop.
Try running netstat -a in Start > Run > Type "cmd"
It will show you whats currently connecting and where to from your desktop.
I have these options in the router...
Security Options
Disable
WEP (Wired Equivalent Privacy)
WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)
WPA-802.1x
IM currently using WEP.. can I use WPA? is it the same sort of thing?
Ok I did that and it just listed a load of desktops with the 192.168.0x ip addreses are these mine?? my machines ip address is different.
I just turned off my laptop and changed the key to wpa and the laptop 192.168.0xx has gone.
I think the ip listed there is the lanport..
Not the adsl port.. does this explain why its different??
Im sorry I told you I was a clueless at this. I still though am getting a download going on in du meter.
