Power saving, simple as.
CPU isnt being used so it down clocks to save you pennies on your electric bill. Helps prolong the life of the equipment too
Seems like quite a few of these overclocked bundles have these stability issues as I can gather from posts in the forum. The best bet is to send a webnote and not meddle with anything for the time being, OCUK should sort you out!
Another thing you can do is to check the temperatures.
be aware if u do it yourself the ocuk warranty will be gone
honesty i don't know, but i would say call ocuk first,Well all i've done is pressed the load fail safe option in bios... I assume they won't tell me i've voided the warranty for that?
All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
Ahhhh i see, so if i put it under load i'll likely see it return to 4ghz? That's pretty damn clever.
