Why is my frame rate and frame time so unstable in every game?
22 Dec 2011
UK
going from a 7600k to a 7700K, didn't seem the most logical upgrade.
Ryzen 3600 or a 8th/9th gen intel would have made more sense.
29 Aug 2013
CPU bottleneck would be my guess, especially in BFV a quad core is not going to cut it with a 2080S
BFV uses 90%+ of all 12 threads on my ryzen 2600 with a vega 56
OP
18 Oct 2019
I don't think so, the 7700k is more than enough, and my friend has the exact same CPU with the exact same GPU and has zero problems. Plus, I had a GTX 1080 before and it did the same thing with the CPU, I don't think the CPU is the issue here. And again, its not just Battlefield V. Its every single game, even Minecraft is unplayable, I am not expert but the i7 7700k is more than enough.
1 Apr 2019
Singlethread sure, when a game actually makes use of all those cores/threads? Nope.
Meanwhile, in the real world:
In some titles, you'd be right. Battlefield V is not one of them.
OP could be having processor related issues still - bad power managment, thermal throttling etc, but with the processor working correctly this is not the issue.
29 Aug 2013
I knew this one would get posted, my mate has a 7700k and it doesn't hold no where near those minimums in 64p multiplayer - especially in more demanding game modes like operations/frontlines. I also believe this was before the big ryzen optimization patch for battlefield 5 earlier in the year. Second one is singleplayer which is irrelevant and not demanding on the cpu, hence the high minimums on the 4 threaded cpus which drop to 40s in multiplayer. He did upgrade and commented:
"here is my experience. I had a similar setup, 7700k @ 4.8ghz, 3200mhz ddr4, 1080ti FE no OC, 1440p gsync 165hz. The gpu never hit 100% and never maintain constant 165fps even in low settings in 64 player maps). But after switching to 9700k & new z390 mobo (ouch) this game felt much smoother, with the occasional stutters / frame drops completely disappeared (no one ever talks about this which ruins the experience in the heat of battle). The 1080ti now always @ full % utilisation."
1 Apr 2019
Every reviewer who has benchmarked both processors in that title have posted similar numbers. Seems much more likely there was an issue with your friends setup tbh.
