Are onboard solutions really that good now?
Why bother when you can have a USB device? The longer you keep the sound purely digital the better.
Passthrough is an entirely different game and you dont need an addin card for that. Onboard audio is fine for an optical passthough as it does no processing.
Depends what inputs/ outputs your monitor has. I use HDMI into my TV which passes the sound through to my soundbar.Yes I did, HDMI does not function properly, as it requires a fake secondary display to be active.
Anyone who had to use Creative drivers over the years will tell you.
onboard sound is so good these days that 99% of people simply don't need sound cards or external DACs.
I have had Creative soundcards since the Audigy days and am still using a Soundblaster Z that I have had since they came out and have never had a problem with Creative's drivers. I updated to the latest one a couple of weeks ago through Soundblaster Command and it was quick, easy and problem free. I have seen massive threads on many forums about their drivers but they have always just worked for me.
Onboard sound is garbage compared to a decent soundcard. I tried it on my last motherboard thinking that it must have improved by now and always felt like something was missing from the sound so went straight back to my Soundblaster Z. It was a Realtek ALC4080 which was one of their best audio chips at the time not one of the budget ones.
You can use an AVR?! Can you show me a picture of your setup?That's fine if you just want two channel. I'm using asus soundcard, optical out to a AVR. I really wanted to use HDMI out on the GPU just for audio, but it doesn't work as it should.
Unless USB audio can pass DD/DTS/HD/Atmos/DTS X etc etc
Can you not use an HDMI splitter? One to monitor, other to receiver ?The problem with lack of digital out on motherboards, I'd need a monitor with HDMI audio pass through / E-ARC or somekind.
If you want awesome audio, just get a good external DAC.
Most cheap splitters strip the HDCP protection bit if that's what you mean.Not unless the AVR receiver side disables the HDMI CEC video check lock on thing, no. Reason why I hate HDMI with all the sync, you get drop outs when you switch on or off the device.
