Wierd GTA 5 performance issues
Good idea but alas the specific profile is set to "use global settings" and global settings is set to "use application"
And application is set to off.
The more I read about this, the more I am seeing that the game purposely has some kind of mechanism not to stress the GPU unless necessary and tries to keep the game between a 40-70fps band...
Doesnt do that for me when I tried. Turn vsync off completely and install the Nvidia driver & physx driver only. Not the game optimization junk
https://i.imgur.com/N7Gk5qX.png
Is urs set to highest?
Also is windows set to your monitors refresh rate setting properly.
Right click desktop, display settings/advanced display setting/display adaptor settings for device/click monitor tab at top/ should say what refresh rate is ur monitors is at, if you have 144hz it should be set there as that if not switch it to the right one.
Btw dont worry about low cpu usage you wont get it that high as if it does all it needs to at 50% usage and fps are ok then its fine. I mean on this vid his cpu like urs doesnt go more than about 60% usage at 4k. His gpu at 99% is his limiting factor not cpu.
https://www.youtube.com/watch?v=-7MvCKUb44w&t=385s
And yeah if you have advanced gfx settings in gta v on id turn em off, there just gona kill ur game even with 2080ti i think. I dont know many that ever have em on.
Besides your cpu usage will rise the heavier the action like 3-5 star action. Use afterburner or something to monitor cpu usage as you cause mayhem.
I mean get put the 1070 GPU back in and try it on the 445.87 Nvidia driver.
That said, something in definately not right. It just looks like the 2080Ti is being limited to 60fps with Vsync. Unless its jsut coincident that all fps average is 60... are you sure vsync is not enabled in on the 2080Ti driver or in a game profile or something?
My results with a 1080Ti, all setting and resolution are the same though driver and system is slightly different. I would expect your 2080Ti to hit ~140-180fps in the average frames
Frames Per Second (Higher is better) Min, Max, Avg
Pass 0, 33.152760, 122.222488, 103.428452
Pass 1, 58.633144, 125.708679, 107.064873
Pass 2, 75.727737, 166.093643, 114.919212
Pass 3, 80.453110, 184.716553, 130.889206
Pass 4, 48.859856, 176.703415, 109.248444
Time in milliseconds(ms). (Lower is better). Min, Max, Avg
Pass 0, 8.181800, 30.163401, 9.668519
Pass 1, 7.954900, 17.055201, 9.340132
Pass 2, 6.020700, 13.205201, 8.701765
Pass 3, 5.413700, 12.429601, 7.640049
Pass 4, 5.659200, 20.466700, 9.153448
Frames under 16ms (for 60fps):
Pass 0: 970/971 frames (99.90%)
Pass 1: 1006/1007 frames (99.90%)
Pass 2: 1054/1054 frames (100.00%)
Pass 3: 1211/1211 frames (100.00%)
Pass 4: 12303/12326 frames (99.81%)
Frames under 33ms (for 30fps):
Pass 0: 971/971 frames (100.00%)
Pass 1: 1007/1007 frames (100.00%)
Pass 4: 12326/12326 frames (100.00%)
=== SYSTEM ===
Windows 10 Pro 64-bit (6.2, Build 9200)
DX Feature Level: 11.0
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (8 CPUs), ~4.0GHz
16384MB RAM
NVIDIA GeForce GTX 1080 Ti, 11667MB, Driver Version 445.78
Graphics Card Vendor Id 0x10de with Device ID 0x1b06
=== SETTINGS ===
Display: 1920x1200 (FullScreen) @ 100Hz VSync OFF
Tessellation: 3
LodScale: 1.000000
PedLodBias: 0.200000
VehicleLodBias: 0.000000
ShadowQuality: 2
ReflectionQuality: 2
ReflectionMSAA: 8
SSAO: 1
AnisotropicFiltering: 16
MSAA: 2
MSAAFragments: 0
MSAAQuality: 0
SamplingMode: 0
TextureQuality: 2
ParticleQuality: 2
WaterQuality: 2
GrassQuality: 3
ShaderQuality: 2
Shadow_SoftShadows: 2
UltraShadows_Enabled: true
Shadow_ParticleShadows: true
Shadow_Distance: 1.000000
Shadow_LongShadows: true
Shadow_SplitZStart: 0.930000
Shadow_SplitZEnd: 0.890000
Shadow_aircraftExpWeight: 0.990000
Shadow_DisableScreenSizeCheck: false
Reflection_MipBlur: true
FXAA_Enabled: true
TXAA_Enabled: false
Lighting_FogVolumes: true
Shader_SSA: true
DX_Version: 2
CityDensity: 1.000000
PedVarietyMultiplier: 1.000000
VehicleVarietyMultiplier: 1.000000
PostFX: 3
DoF: true
HdStreamingInFlight: true
MaxLodScale: 0.000000
MotionBlurStrength: 0.300000
Really dont get it... Ive now done a bench with EXACTLY your settings as below:
Pass 0, 11.407204, 86.869652, 69.672234
Pass 1, 17.398869, 97.177010, 79.859650
Pass 2, 11.942095, 141.211029, 73.474937
Pass 3, 16.464781, 135.655762, 80.516159
Pass 4, 12.213039, 136.052567, 81.600044
Pass 0, 11.511500, 87.663902, 14.352921
Pass 1, 10.290500, 57.475002, 12.521968
Pass 2, 7.081600, 83.737404, 13.610083
Pass 3, 7.371600, 60.735703, 12.419868
Pass 4, 7.350100, 81.879700, 12.254895
Pass 0: 515/639 frames (80.59%)
Pass 1: 668/733 frames (91.13%)
Pass 2: 578/676 frames (85.50%)
Pass 3: 645/731 frames (88.24%)
Pass 4: 8342/9164 frames (91.03%)
Pass 0: 636/639 frames (99.53%)
Pass 1: 729/733 frames (99.45%)
Pass 2: 674/676 frames (99.70%)
Pass 3: 728/731 frames (99.59%)
Pass 4: 9159/9164 frames (99.95%)
Percentiles in ms for pass 0
50%, 13.00
75%, 15.00
80%, 15.00
85%, 17.00
90%, 18.00
91%, 18.00
92%, 18.00
93%, 18.00
94%, 19.00
95%, 19.00
96%, 19.00
97%, 20.00
98%, 21.00
99%, 24.00
Percentiles in ms for pass 1
50%, 12.00
75%, 13.00
80%, 13.00
85%, 14.00
90%, 15.00
91%, 15.00
92%, 16.00
93%, 16.00
94%, 16.00
95%, 16.00
96%, 17.00
97%, 17.00
98%, 18.00
99%, 19.00
Percentiles in ms for pass 2
50%, 13.00
75%, 15.00
80%, 15.00
85%, 15.00
90%, 16.00
91%, 16.00
92%, 16.00
93%, 16.00
94%, 17.00
95%, 17.00
96%, 17.00
97%, 18.00
98%, 19.00
99%, 20.00
Percentiles in ms for pass 3
50%, 12.00
75%, 14.00
80%, 15.00
85%, 15.00
90%, 16.00
91%, 16.00
92%, 16.00
93%, 16.00
94%, 16.00
95%, 16.00
96%, 17.00
97%, 17.00
98%, 18.00
99%, 19.00
Percentiles in ms for pass 4
50%, 12.00
75%, 14.00
80%, 14.00
85%, 15.00
90%, 15.00
91%, 15.00
92%, 16.00
93%, 16.00
94%, 16.00
95%, 16.00
96%, 17.00
97%, 17.00
98%, 17.00
99%, 18.00
=== SYSTEM ===
Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
8192MB RAM
NVIDIA GeForce RTX 2080 Ti, 11584MB, Driver Version 445.87
Graphics Card Vendor Id 0x10de with Device ID 0x1e07
=== SETTINGS ===
Display: 1920x1200 (FullScreen) @ 143Hz VSync OFF
Tessellation: 3
LodScale: 1.000000
ShadowQuality: 2
ReflectionMSAA: 8
SSAO: 1
MSAA: 2
MSAAFragments: 0
MSAAQuality: 0
SamplingMode: 0
TextureQuality: 2
ParticleQuality: 2
WaterQuality: 2
GrassQuality: 3
ShaderQuality: 2
FXAA_Enabled: true
TXAA_Enabled: false
Shader_SSA: true
DX_Version: 2
PostFX: 3
DoF: true
It must be reducing to save power. Is 'Prefer maximum performance' switched on it Nvidia CPL under Power management mode?
You should be averaging 140 - 180fps really. ~40% increase over my 1080Ti
I know tell me about it Guest!
I just stuck on Prefer Max Performance as you instructed and it has helped by 15-20fps...
But like you said I should be well above your results... just doesnt make any sense!
Pass 0, 12.874917, 98.226997, 83.590340
Pass 1, 23.814116, 107.248955, 86.641197
Pass 2, 13.673662, 120.948227, 87.464554
Pass 3, 13.850684, 130.974045, 103.161224
Pass 4, 12.543101, 136.920654, 85.387482
Pass 0, 10.180501, 77.670403, 11.963105
Pass 1, 9.324100, 41.991901, 11.541854
Pass 2, 8.268001, 73.133301, 11.433203
Pass 3, 7.635100, 72.198601, 9.693564
Pass 4, 7.303500, 79.725098, 11.711319
Pass 0: 766/779 frames (98.33%)
Pass 1: 788/804 frames (98.01%)
Pass 2: 786/793 frames (99.12%)
Pass 3: 939/946 frames (99.26%)
Pass 4: 9158/9622 frames (95.18%)
Pass 0: 777/779 frames (99.74%)
Pass 1: 799/804 frames (99.38%)
Pass 2: 789/793 frames (99.50%)
Pass 3: 942/946 frames (99.58%)
Pass 4: 9618/9622 frames (99.96%)
=== SYSTEM ===
8192MB RAM
=== SETTINGS ===
Tessellation: 3
LodScale: 1.000000
ShadowQuality: 2
ReflectionMSAA: 8
SSAO: 1
MSAA: 2
MSAAFragments: 0
MSAAQuality: 0
SamplingMode: 0
TextureQuality: 2
ParticleQuality: 2
WaterQuality: 2
GrassQuality: 3
ShaderQuality: 2
FXAA_Enabled: true
TXAA_Enabled: false
Shader_SSA: true
DX_Version: 2
PostFX: 3
DoF: true
Hmm i thought i mentioned using prefer max performance in nvidia panel awhile ago. Ah well.
Is windows using balanced or performance for power management?
You did Skeet, sorry I didnt ignore you, I did actually turn this on but I think when I did a DDU all my settings dissapeared....
Im on high performance on power management...
Actually Skeet, I just restored defaults on my high performance as well....
Getting there but Im still under Guests 1080TI performance where I should be well above it!
Anything else I should consider?
Pass 0, 25.223162, 140.038376, 85.754013
Pass 1, 50.329910, 104.530342, 86.462418
Pass 2, 56.170937, 135.825272, 97.260941
Pass 3, 59.931919, 153.092468, 116.902489
Pass 4, 28.900648, 155.794785, 87.516693
Pass 0, 7.140900, 39.646099, 11.661262
Pass 1, 9.566600, 19.868900, 11.565719
Pass 2, 7.362400, 17.802801, 10.281620
Pass 3, 6.532000, 16.685600, 8.554138
Pass 4, 6.418700, 34.601299, 11.426392
Pass 0: 799/804 frames (99.38%)
Pass 1: 795/811 frames (98.03%)
Pass 2: 887/889 frames (99.78%)
Pass 3: 1074/1075 frames (99.91%)
Pass 4: 9359/9813 frames (95.37%)
Pass 0: 803/804 frames (99.88%)
Pass 1: 811/811 frames (100.00%)
Pass 2: 889/889 frames (100.00%)
Pass 3: 1075/1075 frames (100.00%)
Pass 4: 9812/9813 frames (99.99%)
Only bench or play at ur monitors res not under it, whats it actually like playing the game? Smooth, avg fps? If its ok then just enjoy it tbh. Might be one of them games that just is iffy on certain configs i dunno.
If your benching it at guests res then the results will be showing cpu results mainly i think. So if you both had same cpu then could be one of you has it oc and the others hasnt or not as much.
Btw hyperthreading is working i presume and not turned off in bios perhaps?
Mmm this also true Skeet. Benches at my monitors res actually yield similarresults as if they were at 1920 x 1200...
Pass 0, 32.279202, 100.981537, 83.854065
Pass 1, 41.250038, 100.305931, 77.382507
Pass 2, 58.855381, 124.540756, 83.477211
Pass 3, 69.821182, 141.484741, 102.971733
Pass 4, 38.401573, 136.765228, 82.822235
But even though with the overclock, I still cant fathom how I am getting lower results....
Guest - what is you rig clocked at?
Maybe the 8GB RAM is the limiting factor? My CPU is also at 4.5GHZ even though it only shows 4
"Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (8 CPUs), ~4.0GHz"
Check yours for things like PCIe bus...
I actually had 16GB in there originally but the pairs are different so took them out, but performance was not much different honestly speaking.
If that was ur native res sorta 4k ultra wide then thats not bad results, just dont use aa and keep reflection aa to 2x and u might squeeze a little more out.
https://www.youtube.com/watch?v=OvExyeZ_AHs vid u might wana watch. Thats with everything maxed (over kill tbh due to the high aa used)
