Will work fine, just plug and play. Wired and wireless controllers are the same
Not true, the wireless one on the PC has numerous compatibility issues, including rumble functionality being broken.
Wired pads, work perfectly however.
What are the other numerous issues with the wireless pads?
Look at the receiver the wrong way and it breaks, literally!
Plug it in, attach it to something out the road of anything and leave it well alone- as in don't un/plug it or bash it about if you can.
I've had about 4-5 of them, most got replaced under warranty but my last one lasted about 2 years.
Dead Rising 2 had issues with the wireless controller, wheras the wired one worked perfectly iirc.
The last 'big' game that I can remember that didn't support it was Mass Effect 1. Ignore anyone who mentions drivers, plug it in and wait for for the standard Windows bubble to pop up saying hardware ready to use.
Mass Effect 2 won't allow gamepad either, as i found out a few weeks ago![]()
I used the wireless receiver for xbox pad. Made Witcher 2 much more fun to play.
You still need the wireless receiver for PC, and as I had to fix mine by soldering the fuse I'm not too keen on using it for prolonged periods of time.
^^ agree, xpadder is great. I think the older version doesn't work on W7 so you need to buy the new one, but works great.
Wireless receiver for PC is a given and i assumed that you were using it on the PC already and just was not happy with running out of batteries.
