will i be over the limit
Permabanned
20 Apr 2010
Had about 10 cans last night, but stopped at about 11pm. Will I be okay to drive now? I'm guessing I will be, and I feel fine, but just thought I'd check. Simple yes/no will suffice.
If you have to ask then probally not is the answer. You won't get stopped, it would only be a problem if you crashed.
I think Carling is about 2 units a can, so that is 20 units, I think it takes 1 hour a unit from when you stop drinking i think, so I would wait 20 hours??
I am not sure if it is from when you stop drinking or from when you start drinking
Kimbie
A chap i used to work with was pulled 2 days after drinking 12 pints and a couple of shots in one evening, he was over the limit and was promptly banned.
What made it worse is that he was in a works van, he also lost his job as he was a delivery driver....no licence...no job.
I wouldnt and never risk driving if i have any doubt in my mind that i might lose my licence and endanger other people.
Kimbie
I was drinking from 8 until just before 11, so if the first few cans/units metabolized before 11, if I don't drive until 12, i'll probably be okay won't I?
Well that's quite scary :eek:
you've had 15 hours since your first units, so in theory enough to loose about 15 units.
You've had about 20 units last night so this early your quite close to being on the limit. I'd personally leave it another few hours. Not worth it over 3/4 hours.
I work on the basis if i have to ask myself then i shouldnt drive. Dont see the point of taking the risk
