Will i notice a difference?
No glass and no shinny gloss its matt.
I would advise (and so does the Don) the 21.6" Aqua as its better built and spec.
I returned a 226 as of Bezel and the 223's are sim.
http://forums.overclockers.co.uk/showthread.php?t=17897543
Can i ask why it's a 21.6? and will it make any difference on the way the res is displayed?
EDIT: I'm really not sure about the SM-2253LW , i've been searching for reviews and can't find any. But then the reviews of the 226 are all 5 stars on ocuk. This is hard :(
I went from a 17" lcd to a 24" a few days ago.. You will definately notice the difference :)
I have the samsung t240 which i guess is similar to the one you are looking for but a tad bigger..
In terms of screen size, theres no appreciable differencebetween 21.6 and 22. They both run the same resolution, same as a 20" monitor, so in terms of how much you see on your screen its the same 20" through to 22".. Only difference is physical size.
This may sound stupid but will it make anything out of proportion?
No, it will still all be in proportion
It’s just a little smaller than a 22”, and compare it to the equivalent 22” screen and it’s a bargain.
I wouldn’t be put off by it being 21.6”, although not a common size do a little googling and you’ll see there are plenty about.
I guess one thing to take into account if you’re going from 17” to 22” is whether your PC can handle the higher res well enough, but as you’re a keen gamer hopefully its fairly up to date?
Can i also ask, can someone summarise the bezel issue with the 226bw?
I got the 226 BW and it had horrible calibration issues - i RMA'ed it and then they sent it back saying that there was nothing wrong :mad:
In the end i went out and brought a pantone huey pro which fixed it. Please read up about the panel lottery with these monitors before purchasing.
