Caporegime
okay then, its a garage that specialises in toyotas and is called, Toyotech...mate...
[TW]Fox;16512497 said:Yet they cant fix a 1.8 litre Toyota engine without the customer printing a DIY guide off the internet..
have you tried getting a quote from an audi specialist as theyd normally be cheaper plus they often know more then the dealers
I took it to an independent Audi specialist this morning after picking it up from Audi. Basingstoke Audi were actually quoting even more than I first thought... it had now risen to £2700 to sort the dashboard and replace the coils, catalytic converter, ECU(?) etc...
The independent guy I spoke with said he would sort the immediate motor problem all inclusive for £575. He pointed out the problem with the broken cylinder and also the ECU He did not see any value in replacing the Catalytic converter or associated parts at this stage - this was completely overkill in his opinion.
With regards to the dashboard - he has suggested that rather than jumping into replacing it straight away that I should try the original key that I bought with the car. I paid for Basingstoke Audi to provide me with a new key and do the programming when I first bought the car (another £130...) He said it maybe a problem with the coding on the new key which is causing the immobiliser to kick in unnecessarily and thus cause the resetting problem. If it is a case of needing to replace the dashboard he has offered to send the existing one off to get it repaired so that it is not too expensive as I will not need to reprogram my keys etc
I think the thing that has been clear to me after today is that the official Audi dealerships cannot be trusted one bit. It was apparent on the report they provided that they had done minimal investigation into the problems I was having (e.g. they put they "suspected" I had a faulty dashboard rather than confirming it - and decide I should pay £650 to replace it). The customer service as mentioned before has also been extremely poor there - making you wait for long periods in the showroom to be seen and not returning calls despite assuring they would reply ASAP.
It's a real shame as I think the cars are great to drive but the customer service and dealerships have put me off for life.
I bought an Audi A3 2.0 FSI Sport (2004) for £9,200.
So overall I am looking at a £2310 repair job. I do not have huge sums of cash right now so I am potentially going to have to go into some debt to pay for this.
Sounds like you overstretched yourself financially in the first place.
Should have bought Japanese, got a Lexus IS200SE for 12k, still going strong at 56K miles, though it does wear out tyres rather quickly.
i dont have time to read all but how the hell cylinder, dashboard and coil broke at same time?
wtf?
That's a bit harsh. I certainly don't keep £2000 lying around in case my car needs an expensive repair.
Stop trolling and move on.
Be quiet. I'm teaching financial responsibility.
If your life savings amount to £10k, you don't splurge £9k of it on a Audi A3. £9k = a spend of £4-6k on a car depending on your approach to risk, with the rest saved for a rainy day. He'll be up **** creak if he was made redundant from his job for example.
Get knotted! You're trolling from a holier than thou pulpit that doesn't remotely approach anything called normality.
To compound it you provide a fatally flawed example. Need some cash? Sell the car and buy a £1k repmobile. It's not like he's had no deposit and got it from Carcraft on finance over 5 years.
Move along now.
