Hi, I'm trying to fix my brother's laptop, well sort of, lol. The problem is that you the wireless network I try to connect it to it won't connect, you get the standard can not connect to network, I've tried diagnosing, and some other things, problem is my bro is one of three flatmates (students) and both the others are connected and using it fine and will be would be disconnected if I turn off router, (the router is a white netgear adsl router) sorry I can't explain in more detail, I'm an it technician and even baffled, problem is I'm not very good at windows 7, I'm an XP man.
Any advice and solutions greatly appreciated.
Many Thanks
The Scop
Many Thanks
The Scop
