Wireless flash triggers
have a search over on TP for a guy called "flash in the pan" he sells all sorts of flash stuff for reasonble prices, he comes well recomended.
The shop i mentioned above sells a lot of the stuff he has but without his cut ontop :)
Another vote for the RF-602s, very impressed with mine. Every bit as reliable as the Broncolor wireless kit I use in the studio!
Well now I can return and say they really are every bit as reliable as the Bron kit, as they both broke :D
Trigger stopped lighting up when you pressed the button. Light oddly flashed on when you inserted a battery, but no life thereafter. Must have been a dodgy unit! The seller (gs12307) refused to answer my emails until a paypal claim was made and my money returned to me. There are now a couple more people popping up with them so I would recommend against gs12307 if you wish to have any support should they fail prematurely.
MRK, I just tested again with it setup as you do above, but I guess it isn't syncing properly. If you wirelessly trigger the camera, does the flash fire at the right time to be captured? I hope that makes sense.
EDIT: Just done some googling, and it seems you MUST have a transmitter on the hotshoe to sync with the flash properly. So I need another trasnsmitter.
