wiring help (Again)
Exactly how I did it, On on start up, turned off fine, turned back on and my 230w Micron I think it was; PSU goes 'pop'.
Might just have been the pants PSU I was using to test it, works fine with everything else :p
As you can see switch works a treat :) but doesn't illuminate :( (tried connecting to the other outer terminal but it doesn't work at all then) so it looks like i need another one :(
You have to wire them up specially mate.
There are instructions on the net I will fish out for you later unless you followed/find them.
Just had this reply from my e-mail :)
"Sorry to say, it seems we have made a tiny mistake with those switches. We intended to order 12v illuminated, but it seems we have ordered mains powered switches. The 12v of the PSU is not enough to light the bulb, but the switching action obviously works fine.
We are looking into sourcing a replacement that is 12v light able, and will let you know with what we find. Once we source one we can sort out the replacing of the unit."
