I recently got my 980ti (refrence card) and it is great (coming from a 780ti). Now playing Witcher 3 at 1440p with all the settings set to ultra, minus hairworks and I cannot get a stable 60fps. Most areas I get 60fps but when its raining or wind is blowing through the forest frame rate fluctuates between 60 - 45fps, which is extremely annoying.
Using nvidia inspector I have:
forced vsync on (disabled in-game vsync)
enabled triple buffering
set max pre-rendered frames to 1
enabled FXAA (disabled in-game AA)
set power to "prefer maximum performance"
set Threaded optimisation to "on"
Using the setting above has smoothed things out a bit but i'm not satisfied. I know fps can be gained by lowering settings but if possible would like to avoid doing this, as this game was one of the reasons for the pricey upgrade.
Also as its a reference card i thought the heat was reducing the boost clocks so i have set custom fan profile which allows maximum boost clocks with good temps (77 degrees max). I have not overclocked the card.
I was under the assumption that this game ran smoothly at 1440p - Ultra settings with a 980ti based of various benchmarks and reviews, so if Anyone has any tips, tweaks, settings or suggestions would be much appreciated.
