Wolfdale 8500 Temps ??
18 Feb 2006
Halifax
Hi
Just a quick question guys, this is for owners of the E8500 only,
I installed an E8500 into an Asus P5N32-E SLI - The Cpu cooler is a Tuniq Tower using Artic Silver 5.
The temps never seem to get lower than 45c :confused:I have re-seated the Cpu 3 times and the temps have remained the same. For those of you with the same set up its a real pain as I cant reach the thumb screws so this involves removing the MB. I have phoned Intel technical support and they have said that the E8500 does run hotter than the other Wolfdale Cpu's ie.. the E8400.
They also said that I'm using a Beta Bios 1403 and that this bios could not be reading the correct temps from the Cpu.
Any other people using the E8500 and if so what are your temps
Many thanks for taking the time to reply
PC Spec
Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB)
Tuniq Tower 120-LFB CPU Cooler
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
OCZ 4GB (4 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
2 x Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache RAID 0
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
Creative Sound Blaster X-Fi Platinum Fatal1ty 7.1
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Antec P180 Advanced Super Midi Tower Case
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
Razer Tarantula Advanced Gaming Keyboard
Razer Diamondback
Creative Fatal1ty Gaming Headset
Vista Ultimate 64bit
2 x Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
3 x Antec 120mm Silent case Fans
Netgear DG834N 270Mbps RangeMax NEXT Wireless ADSL2+ Modem/Router
Netgear GS605 5-Port Gigabit Desktop Switch
