Work unit P2605, 1760 points...
I just had my first SMP stopped, as it failed to meet the deadline. Has anybody else been struggling. I have been fine for the last couple of weeks.
not had any issues!
Mine runs close to the preferred dealine with these larger WUs - [email protected]
Also since they use more of the CPU there's not enough slack to make running my GPU client worthwhile.
If this is the way things are going I may have to go dual-boot sooner than expected :o :p
edit: That's on 24/7 and hardly any gaming or other CPU hungry activities :eek:
That doesn't sound right, or maybe it does
.8 extra = 16% faster
60sec less = 14% increase in proformance
£200+ = 300% the cost :eek: ... cheap chips for the win :D
What chipsets/Mobo are you boys running your C2D on and ram/hhd would be nice too.
Gskill HZ running at 900
Nvidia 680i chipset (EVGA)
WD Raptor 10,000 16mb cache
any ideas, I am running mine through VMware??
Stelly
I get anything from 14 mins to 22 mins a frame in VMware with two running
Code:
[16:20:09] Writing local files
[16:20:09] Completed 135000 out of 500000 steps  (27 percent)
[16:41:48] Writing local files
[16:41:48] Completed 140000 out of 500000 steps  (28 percent)
[17:03:04] Writing local files
[17:03:05] Completed 145000 out of 500000 steps  (29 percent)
[17:23:51] Writing local files
[17:23:51] Completed 150000 out of 500000 steps  (30 percent)
[17:37:55] Writing local files
[17:37:55] Completed 155000 out of 500000 steps  (31 percent)
[17:59:00] Writing local files
[17:59:00] Completed 160000 out of 500000 steps  (32 percent)
Got this for a nasty nil points! :(
[16:12:34] Completed 465000 out of 500000 steps (93 percent)
[16:34:46] Writing local files
[16:34:46] Completed 470000 out of 500000 steps (94 percent)
[16:56:59] Writing local files
[16:56:59] Completed 475000 out of 500000 steps (95 percent)
[cli_1]: aborting job:
Fatal error in MPI_Sendrecv: Error message texts are not available
[0]0:Return code = 0, signaled with Segmentation fault
[0]1:Return code = 1
[0]2:Return code = 0, signaled with Segmentation fault
[0]3:Return code = 0, signaled with Segmentation fault
[17:02:30] CoreStatus = 1 (1)
[17:02:30] Client-core communications error: ERROR 0x1
[17:02:30] Deleting current work unit & continuing...
[0]0:Return code = 0, signaled with Quit
[0]1:Return code = 0, signaled with Quit
[0]2:Return code = 18
[0]3:Return code = 0, signaled with Quit
[17:06:53] - Preparing to get new work unit...
[17:06:53] + Attempting to get work packet
[17:06:53] - Connecting to assignment server
[17:06:54] - Successful: assigned to (171.64.65.56).
[17:06:54] + News From Folding@Home: Welcome to Folding@Home
[17:06:55] Loaded queue successfully.
[17:10:56] + Closed connections
Just my luck!
Concorde Rules said:
22 mins a frame with two running on a 430x8 Conroe.
Getting 22mins a frame running two just now however I'm running 9x355, for some reason I can't boot up with 400x8 or 7x400 however I can run the ram upto 475 on a divider or run it at 3-3-3-3-12 at 355 (G Skill HZ ram) so not sure whats stopping it.
What Mobo?
Stelly said:
hmm do you think its limited in some way??
Stelly
75% cpu use, yeah guess so.
wonder why they don't have it using 100%?
guys doing two cores, 22+ mins a frame is bad surly?
if I get 7-9mins a frame with 1, unless I'm gonna get 18-20mins at the outside it would be bad?
also I'm running a normal core aswell using the spair!
Im running two...
VeNT said:
two SMP cores,
but your two cores take more than double my single core.
:/ well I am using the PC aswell.
Project : 2605
Core : Gromacs SMP
Frames : 100
Credit : 1760
-- SMP1 --
Min. Time / Frame : 22mn 29s - 1127.23 ppd
Avg. Time / Frame : 29mn 20s - 864.00 ppd
-- SMP2 --
Min. Time / Frame : 22mn 50s - 1109.96 ppd
Avg. Time / Frame : 29mn 55s - 847.15 ppd
:confused:
you talking about the same WU's here? The p2605 seem to use most of the CPU time (90-95%) wheras the p3025 which everyone was getting before was only using around 75%
However you're probably right about not running two of these more demanding ones together as there could easily be some bandwidth issues
