mehuk said:Also, is 279 for console plus 2 games worthy?Thanks
mehuk said:Thanks for replies
Im also speakerless, im assuming PC Headset works with the 360? and the mic for live? (Sennheiser)
Yes, by using the 'line in' port, however you would be using the Red and White cables, i.e. R/L, so you won't get 5.1 audio. Optical is what would be needed for that.mp3kla said:Sorry to hijack, but I noticed u said the 360 needs to go to something else first b4 speakers? Would it hook up to my pc ok, and play through my PC sound?
Shamikebab said:The headset only provides you with voice chat (and some sounds in a few games) you do need speakers, for 360 you can either use Optical or Phono jacks
NokkonWud said:Yes, by using the 'line in' port, however you would be using the Red and White cables, i.e. R/L, so you won't get 5.1 audio. Optical is what would be needed for that.
mehuk said:that puts me off then - i prefer headset for sound over speakers
why didnt they think of this when building ffs - not everyone wants a surround sound system, im happy having a headset on to listen to when playing
Shamikebab said:well i can plug my headset into my Z5500 control centre to play 360 with a headset if i want to, but theres no option to output straight to headset afaik, i dont think you can do that with any console
mp3kla said:Ah cool, I've got a sterio that is hooked up to my PC, its got a phono to two fat ones, red n white, they go into the back of my speakers. Would they work with the 360, and link it up to my speakers?
