Would You Get an Oil Change?
[TW]Fox;28125591 said:
Can't say I've ever seen the X6 recommended on here.
I've noticed it a number of threads a while back and it see it pop now and again.
Nobody recommends an X6, it's an expensive, overpriced and very niche car, anyone who wants one knows they want one and anyone who doesn't is better off with something else. You are mistaking the constant stream of rubbish from that guy whose Mum was buying him an X6 for 'recommendations'.
Ahh yes that's the one. :D
ElliotJames I believe. Where is he anyway? Crashed his X6 coz mummy couldn't buy him sense?
In answer to the OP though. Yes. Change your oil and filter.
Do you find the clutch very heavy in your car? Mine is, to the extent that if I'm in traffic for half a mile, my leg starts to ache. However, I'm not sure whether it's normal for the car, or related to wear. I don't want to spend the money to change it anyway.
Nope. Could your slave cylinder be leaking? Clutch fluid be low?
according to my Focus Haynes manual (petrol) if your doing really low mileage, you need to change it more often, so every 6 months
