WOW problem updating
15 Jul 2007
South West
Hi the last 2 updates patches for wow have been downloading really slow for some reason?
Im currently downloading tuesdays patch at 2.5kps which is ridiculous,only firewall i have is on my BT home hub which is new and i dont know much about, all other downloading is fine and i can max out my connection np.
Has anyone else had this problem in the past if so is there a soultion.
You can try putting these 2 options on in View > Preferences (not sure if any of them are on by default but i have them switched on anyway)
Or you can as the above poster said just use a patch mirror, gamershell.com is one of the places i usually use for wow patches.
I would assume it was BT that was limiting your broadband, they do that between the hours of 5pm and 12am and the blizz downloader is seen as a bit torrent type program and, therefore, limited.
