Good luck with whatever it is you're trying to do then, thanks for your gratefulness to those that attempted to help in the thread and your way of expressing it.
WTF?! So the time and effort people put into trying to help you means nothing if they cannot solve the issue for you?
It has been solved. Your adaptor clearly doesn't support WPA, however, whilst others didn't know that, they/we took our time to attempt to help you. Never mind.
Only 350 series and CB20A cards that are installed on computers running Windows 2000 or XP and running LEAP or host-based EAP authentication can be used with WPA
Yes, the card doesn't support WPA. I'm now probably going to have to look for one that will. I just wish someone could have told me that nearly a week ago when I started the thread.
Time and effort? If it was that hard to post a screenshot of your wireless configuration window then I apologise.
I really don't see why you have started to get so defensive; maybe I should have littered my post with nice smileys?
Never mind, I wasn't particularly talking about the effort I had put in (indubitedly not much), rather the reponse to some others and how people on here don't appear to appreciate people attempting to help, but don't worry about it.
Using the cisco drivers, but windows wireless zero to connect with, all I had to do was doule click my wireless lan's name and enter the WPA key (as normal text) in the box and it connected straight away.
Looks like its just the windows CE drivers which need it in hexadecimal form now.
This is going to a Linksys WAG54G router, not that it should make a difference.
