write protected USB
1 Aug 2012
hi i am trying to format my kinsigton data traveler. but whenever i try to format it. its showing me write protected error. :mad:
any HELP
check to make sure there is no switch or slider on the side to write protect it if not you could try
Click > Start > RUN > type "CMD" Then
Type "CHKDSK" and type the drive letter of your USB drive and "/F".
Example: chkdsk Q: /F > Enter (Q: being the drive letter)
not sure if tey will work just an idea for you
Right click on the drive and select properties, check to see if certain permissions have been denied.
possible fault with the pen the other thing you could try is go to disk management and try deleting the partition altogether thats the only other way i think
reading on google there is quite a lot of this with kingston sticks
