up to 24-bit/192kHz audio
2 balanced analog inputs (1/4” TRS)
2 balanced analog outputs (1/4” TRS)
S/PDIF digital I/O (coaxial RCA connectors) with 2-channel PCM
SCMS copy protection control
digital I/O supports surround-encoded AC-3 and DTS pass-through**
direct hardware input monitoring via separate balanced 1/4” TRS monitor outputs
software routing of inputs and outputs
digital I/O can be routed to/from external effects
16-channel MIDI I/O
ASIO, WDM, GSIF 2 and Core Audio driver support for compatibility with most applications
64-bit driver support for Windows
PCI 2.2 compatibility
Apple G5 compatible - Incompatible exceptions
includes Ableton Live Lite 4 music production software, so you can make music right away
works with other Delta cards*
* check
www.m-audio.com for current system requirements
** Windows XP required for Dolby Digital and DTS “pass-through”; Mac OS 10.3.4 required for Dolby Digital and DTS “pass-through” with Apple DVD Player
general
sample rates (kHz): 44.1, 48, 88.2, 96, 176.4, 192
main inputs
max input (balanced): +14.2dBu (4 Vrms)
max input (unbalanced): +14.2dBu (4 Vrms)
signal to noise ratio: -113dB @ 48kHz (A-weighted)
dynamic range: 113 dB @ 48kHz (A-weighted)
THD + N: 0.0006%, 1kHz, -1dBFS @ 48kHz
frequency response: +/-0.1dB, 20Hz to 20kHz @ 48kHz
crosstalk: -130dB, 1kHz, channel-to-channel
impedance (balanced): 20k Ohms
impedance (unbalanced): 10k Ohms
main outputs
max output (balanced): +14dBu (3.9 Vrms)
max output (unbalanced): +8dBu (1.95 Vrms)
signal to noise ratio: -108dB @ 48kHz (A-weighted)
dynamic range: 109dB @ 48kHz (A-weighted)
THD + N: 0.0023%, 1kHz, -1dBFS @ 48kHz
crosstalk: -105dB, 1kHz, channel-to-channel
impedance (balanced): 300 Ohms
impedance (unbalanced): 150 Ohms
