pallys said:
X-Fi isnt best for Music or DVD's IMO..
and Dolby Digital is hardly a lossy codec in practical terms eg. playing a music CD is already such poor quality that DD encode wont strip it..its like saying Dolby Digital DVD sound is **** because its a lossy codec..
Well, the lossy part is one of the lesser disadvantages of the DDL cards. The point really is that there's absolutely no advantage in buying a DDL card unless your only input is via co-ax or optical S/PDIF. Lossy codec + slight audio lag + poor game support for a couple of quid more than a card with good game support? I'm sure there's logic there somewhere
well any non creative card supports EAX 1.0/2.0 and the newer games also support the emerging standard OpenAL.
They support EAX1.0/2.0
emulation. The X-Mystique and related cards throw a fit with a few games because of poor EAX implementation. You may have a point about OpenAL (I don't know a lot about it). I think EAX5 runs over OpenAL anyway?
The Dolby Digital cards are useful if he uses with a home cinema setup to watch his DVD's etc or any surround sound gaming. With an X-Fi card you have to use Creative speakers for digital output (AFAIK) because Creative use propritary connectors for this, maybe the breakout box overcomes this.
The ideal solution is to use analogue outputs for gaming as it means the sound doesn't have to be encoded/decoded before being converted to analogue. DVDs can be listened to over S/PDIF on the Creative card or just over multi-channel analogue decoded by the card (like pretty much any multi-channel sound card). You can get a standard co-ax S/PDIF output out of pretty much any Creative sound card using a 3.5mm -> Phono adapter.
I have an X-Fi myself and I can say IMO its a card for a gamer first everything else second, it has have fancy CDMSS-3D 'psuedo' sound algorithms which is **** anyway...
Personally I think the pseudo surround using headphones is quite convincing, but I guess that's a matter of personal opinion.
The things Gibbo asked for I think suit the X-Fi perfectly:
DVDs - Will sound the same on virtually any sound card
AVI - If they have an AC3/DTS soundtrack then same as above
Games - Only choice = X-Fi
He might have a kick-ass stereo for listening to music, or is just not that bothered as he didn't list it in his requirements.
I also found the Creative drivers poor and unstable with snaps, crackles and pops in the output.
Driver stability has been fine with my X-Fi (I had one before that was really quite unstable so sent it back, but this one has been spot on). I did have some snaps/crackles before I sorted out my IRQs though.
The Intel HD Audio is actually a very good product. spend the money on better speakers imo
Never used it so can't comment on that bit.
I know I probably sound like a Creative sales-person here, but I genuinely think the X-Fi is the better card for what Gibbo's asked for.
squiffy said:
Bit of a sly marketing technique really.
I don't think the main objective of this was marketing tbh. Sure Gibbo could probably just pick one off the shelf, but he's just asking for opinions.
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
