Heya. I have the exact ( almost) with diff graphic card and diff memory brand.
My problem however, is VGA cable has an output , but both DVI dont. Is it the same problem? Everything else is identical
Well the original problem in this thread seems to have been that the 12V_ATX CPU connection was not installed. Is yours?
If it is then my next guess would be a graphics card problem, are all the power connections installed?
Would you be able to tell us your full spec so we can help you further?
Antec Trupower 650WWhat PSU are you using?
New system.Has the system ever worked properly through the DVI port?
Also, do you have a spare PCIe graphics card you can put in your system (so you can eliminate the chance of being a problem with something else in your system) or even better, can you try the GTX 460 in a another machine?
Finally, when connected via DVI do you see the BIOS messages when the system first boots up, or is it always off? What monitor are you using out of interest?
Ah, ok -cool.
What adapter were you using and where was it connected (on the graphics card or the monitor)?
Out of interest, what DVI/HDMI monitor are you going for?
Aye, that's the way to connect it.
What is the DVI to VGA adapter that you are using? AFAIK that card didn't come with one. Also, when you got it working via DVI on your friends PC, were you using the same adapter as the one that failed to work before?
I had a look at those monitors. They seem fine: TN LCD monitors with LED backlights. I woudl strongly suggest going for the Samsung over the LG as their LED backlighting is much better implemented.
Out of interest, how much are you planning to spend on a monitor and what do you plan to do with it? I may be able to recommend you something better.
