X58A UD3R (OC Bundle) Problem
I've used CPU -Z x 4 times running, and the CPUs temperature was no more than 62.
Played final fantasy 14 ( a demanding game) and GPU was at 72 at 40ish % game speed, guess thats good too.
Mind telling me, Ive connected my monitor via HDMI , and my sound output is currently Nvidia High Definition . There is no output if i chose my Asus soundcard as sound default. Is there a quick fix to this ? :P
As far as I know, the HDMI pass-through just uses the onboard sound - however as it is all digital it should be fine.
If you want to use your sound card you will have to hook the sound card up to the TV separately.
I'm not sure how the sound quality will compare between the two - I'd suggest testing both out.
