So just to be sure, even though it says in order to use the code you have to have a Brazilian Xbox account. You just vpn into the Brazilian Xbox site to redeem the codes then once done, you can turn the vpn and just use your Xbox on a normal UK internet line??Just buy the code normally from cdkeys first
https://www.cdkeys.com/xbox-live/memberships/12-month-xbox-live-gold-membership-xbox-one-360-brazil
Then fire up the vpn before redeeming at xbox.com/redeemcode
Once it's taken the code, you don't have to use the vpn again
. I only remembered I wanted to do it because of this thread and the billing notification that his Gold had switched to monthly again
I wanted to try the service from them before but have not done it yet.
