XBOX Wireless controller Question?
13 Apr 2009
Hi i've got an XBOX 360 wireless controller for windows and was just wondering does it turn off automatically? Because the light is still on all the time, I have to open the battery compartment up to turn the controller off:confused:
I dont have a pc one, but an xbox one turns itself off (and the light around the xbox logo, which tells you which player you are) after around 20 minutes.
It turns off after a while. No battery drain for me either, had the same set in for months.
It does turn off, but I usually just push the button to open the battery compartment and move it down by about a mm or two - this switches it off but saves faffing about with completely removing the battery pack!
