Joey, i have the Rev B adapter and have the same 'no sound through HDMI' problem you have so buying the adaptor wont help you. Have you tried what i did a few posts up to get it working?
Realtek have a ATI HDMI driver, do you have realtek onboard sound on your mobo? if so maybe worth downloading realteks own HDMI driver.
i have the p55-ud4 :S i believe i do have realtek onboard, can u point me to the correct driver?
i have an xfx 4890 and i wish to connect it to my hd tv .. however in the box there was no dvi to hdmi converter so i had to buy one . the picture worked but there is no sound.. i tried to select it as defualt sound thingy but it says hdmi output not plugged in the control pannel (windows 7 btw).. what can i do to solve this frustrating problem??
cheers man! only a couple of days til this new part gets delivered and fingers crossed!Good luck Joey, i have run out of ideas. I have actually got mine working now but i have to turn my tv off then back on again while my pc is on and it then recognises it is plugged in on the 'playback devices' list and the status changes from 'not plugged in' to 'ready'. If you have any luck then keep us informed i am not religious so i won't pray for you but i will raise a glass to you tonight and say "to Joey and his 4890"![]()
