xfx 4890 conections problem????
7 Sep 2003
i see it has a 6 pin and a 8 pin. but my psu 8 pin does not match up ???? it comes directly from the psu does it need an 8pin and 6pin or 2 6pin connection ??? nee help just bilt a i7 setup but i have put my old 1900 in for the time bieng did not wont to brake my new card
What PSU do you have?
I don't know if these are physically the same connectors, but most PSUs also have an 8pin cable for use with modern motherboards.
JeanTech 600W Modular Arctic Active PFC, 24-pin PSU
600 Watts output
Advanced cable management
Support both 20pin and ATX12V 2.0 24pin motherboards.
20+4 main connector -- 20-pin and 24-pin dual use main connector
All cables sleeved for easy management and optimum air flow
Dual S-ATA power connector included.
Active Power Factor Correction (PFC)
120mm high quality ball bearing fan design
Automatic fan speed control (A.F.C) or smart fan
Easy Connect Peripheral power connectors -- now removing the
power connector from HD or CD ROM drive is as simple as
squeeze-and-pull !
I/O Switch for manual shut-down.
Over Voltage Protection,
Over Power Protection,
Circuit Protection
Support EPS 12V 8pin Connectors
Unit Size : 150mmx140mmx86mm
Net Weight : 2.35KGS
Maximum Power : 600W
Switches : 230V ONLY
Special connectors : 1* 20+4 P, 1* PCI-E 6PIN, 2* SATA
Transient Responser : transient load slew rate is = 1.0 A/µs.
P.G. Signaler : 100-500mS
Over Voltage Protection recycle AC to reset : 1 second
Input Voltage : 180VAC~264VAC
Input Frequency : 47-60Hz
Input Surge Current : 100 amps maximum/230Vrm
Input Current : 6A
Hold-up Time : Hold-up>16mS
Efficiency : power supply is a minimum of 72% efficient
EMI/RFI : EN55022 CLASS B
600 Watts output
squeeze-and-pull !
Circuit Protection
Support EPS 12V 8pin Connectors - This is a motherboard 8pin, that whys it won't fit.
Input Current : 6A
You only have one 6pin pcie cable, which means you would need to buy a molex to 8pin pcie adaptor to get the card to work. However I have only seen a molex to 6pin pcie adaptor. Although if you can find one, the PSU certainly has enough amps and watts on the 12v rails to easily power the card.
Edit:- Type the following into google, then click the shopping tab, first product that appears. It should be black and green :)
"molex to 8 pin pcie"
When you get this plug the real 6pin pcie cable that your PSU has into the 6pin socket on the GPU, and then use this adaptor for the 8pin.
Surely it's worth a punt to try the adaptor first? Your PSU should be able to run an i7 with a single card fine (38A on the 12v is fine).
cant find one m8,dident see it on overclockers m8
thnx for pointing out the 8 pin to the motherbaord was using a a 4pin from my e6600 setup was working ok thow ,just built an i7 30 minutes ago and cant put my 4890 in it :( have now put the 8 pin to motherboard :)
