XFX 8800gt problem
30 Dec 2006
Lowestoft.
Picked up a reasonably priced 3 month old XFX 8800gt from a popular aution site. When installed PC won't boot/post. All fans (processor, graphic card and case) all spinning. Hard drive doesn't access and monitor stays on standby. If I put my Galaxy 7900gs back in, everything is OK. Could this be a power problem (vantec 460w), I am currently branching off power from the hard drive supply.
Thanks for the replies. Would giving it its own power (not branching from other hardware) help this problem?. Is motherboard compatability a likely problem? Would a low power supply problem cause the issues I'm currently experiancing?
Anyone else had problems running a 8800gt in a Gigabyte GA-K8N-SLI or other older socket 939 boards???
Any suggestions for a fix????
Running a 8800GT on K8N Pro SLI without problem.
Try giving the card it's own power or trying booting up with less hardware attached to the PSU.
PSU should power it fine, got 30a on the 12v rail, could be as your branching it off from your hard drive, i was powering my GT fine on a PSU with only 28a on the 12v rail.
Have just swapped card into PCIE x 16 slot 2. PC now boots as normal. Running 3d mark 06, card stated as 8X not 16X. Will this affect performance considering my relaqtivly slow processor? Why will it work in slot 2 at 8X but not in slot 1 at 16X?
Because both the slots are physically PCI-e x16 however the 2nd one is electrically 8x
3D mark 06 score was 6740 up from 4250 with 7900gs. Compared to similar systems online it seems reasonable, so 8x dosn't seem to affect performance to much.
Anyone any comments on the score?
