Xfx And Freesync
31 Oct 2009
in the tower
Hi i just bought a Freesync monitor as i have an XFX 290 but can the 290 work with freesync ? and what kind of displayport cable do i need to order as there are a few different ones
Hi tommy i just opened the box tonight and the cable is an hdmi one so i know i need to order one but not sure what one to get ? any advice appreciated
Amd have shown freesync to work on hdmi on some new monitors ( not sure if that's one you have ). If not then you have to use dp.
If you have to have freesync over dp then why oh why didn't they supply one with the monitor!!!
Thanks this is the one i have just got today and i will connect it tommorow night but im not sure if i need the displayport cable or not
https://www.overclockers.co.uk/lg-2...e-widescreen-led-monitor-black-mo-128-lg.html
I think all dp cables are the same but there are different versions of them, I would buy a dp 1.2 cable as they all seem to work with freesync.
If you get screen tearing then the cable is no good so I would try to get a decent ish one, not an ebay cheapo crap.
Your monitor being a Freesync display should have came with DisplayPort cable I know my BenQ XL2730Z did and I thought it was hdmi at first. You sure it's hdmi cable?
Buying a cable am sure it needs to be displayport 1.2a or freesync won't work.
Hdmi Freesync isn't out yet coming 2016 with new GPUs and displays.
Don't cheap out on a DP cable for FreeSync as shankly said, FreeSync cable has a requirement, AMD have a certified supported list somewhere.
I know Accell B142C-007B is one of them(but usually hard to track one down), I bought one when I had my BenQ FS.
Or get a cheap one delivered as quick as you can for over the holidays, could be fine anyway.
Why LG don't supply a DP cable I do not know:o
My advice would be to pay a little extra and get a decent, high quality DisplayPort 1.2 cable. There is a lot of cheap junk floating around. I can personally vouch for and recommend this cable.
Accell UltraAV B142C-007B DisplayPort to DisplayPort 1.2 Cable with Latches (6.6 Feet / 2m)
You can find them on the rainforest the last time I looked its where I got mine.
The cheap junk reputedly doesn't work correctly with 4k it can't handle the frequency screen will black/blank out apparently and they certainly don't do Freesync in my experience.
Well i picked ap a Displayport cable today and it does not work as the crimson software says freesync not available and i get screen tearing in wolfenstien the new order
Is there anything in the monitor's menu's you have to enable to turn freesync on?
I know with my BenQ one I had to turn off the Blur Reduction. Even after I did it didn't let me enable Freesync until I had turned it on and then off a 2nd time.
